Hi friends,
While I am playing the game in between it was crashed without any further message. I not able to get any further information about why it is happened all of a sudden. I am good at playing and very bad in finding the fixing the problem. How do I resolve this error to continue my game? Please help. Thanks.
Error
Fatal Error
How I will resolve fatal error to continue my game
There can be any number of reasons for this error. To try and narrow them down, try the following steps
1. Launch the game but don't play it, just let it stand there for 10 minutes. If it crashes, it is possible that you have a problem with either RAM (physical memory) or your graphics card. If it doesn't crash, move to step 2.
2. Enter the first level (or load the first save game) where the error appears and let the game stand there for 10 minutes. If it crashes, then it is most likely RAM or graphics card issue. If it doesn't crash, move to step 3.
3. Play levels or load savegames until you can find such a level or savegame where the game crashes every time. In other words, try to make the game crash and you will find the cause of the error.
Once you've found the place where the error always appears, you can use cheats for the game to skip that level and see if you can play the rest of the game normally.
