zisanwiliam
Posted on - 10/07/2011
I have micromax q7 handset. It does not have pc suite. But it work in Bluetooth network, how I will connect it with my laptop Bluetooth and use it internet in my laptop by my mobile phone set?By the way phone model shown in my laptop bluetooth.
aldean
How I will use internet by phone to laptop via bluetooth?
First is new need to connect your mobile to the Internet via e.g. 3g connection. Next on you computer look for the program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth). Select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
If you aren't prompted on your laptop for the type of service to use with your Bluetooth phone, try going into the options menu of your Bluetooth application to find that setting.
jimmytoy
15 points
Yes I have an answer of you question and it is also the solution of your problem. First of all it must be sure that both devices are working properly and also these recognize to one another. Now please go to the setup of Bluetooth modem properties in your windows. Now go to the control panel of your laptop and reach to there phone and Modem options, these must be like in this form as Control panel >> Phone and Modem options >> Modems >> Bluetooth Modem >> Properties >> Advanced. Than in the extra initialization commands field that you needed to enter (al+cgdcont=1,“ip”,internet3.voicestream,com”). Keep in mind these should be without the brackets. When you will connect from the icon of Bluetooth on your laptop, use your username and password blank and after it enter a dial number of *99#. The connection will not be work when you will be talking on your phone, when not it will work properly and you can use your internet.
