How to identify fake Samsung tablet PC Antivirus?
How to identify fake Samsung tablet PC Antivirus? I have read that there are a lot of them available on the Android App.
In my experience, the best way to identify them is if the name is unfamiliar. The best way to know if an antivirus is genuine is to make sure you download it directly from its own website and check if they offer the antivirus for Android mobiles/tablet. If they don't, then you are sure that the one you see on the Android store is fake.
Hope this answered your question. Good luck!
At first I thought you were asking how to distinguish a fake Samsung tablet. Anyway, the best way to avoid downloading and installing fake antivirus programs is to download the software from reputable sources such as its official website or software store like Google Play. You can also find lots of antivirus downloads from different websites that are maybe posted by fellow users.
There are times downloading these contents are good because you happen to download a clean file but sometimes you will end up downloading infected files and this is the very common one. That’s why it is still very wise to download the software from the original source. Here are several antivirus programs you can try on your Samsung tablet PC.
