jhondeng
20 points
Posted on - 08/08/2011
When i watch a movie With KM player in my computer it plays all kinds of video and audio format.But problem is if i click on forward button of the player or use right arrow key for going forward of that movie then the player automatically hang up.Then i have to press ctrl+alt+del button for go to task manager for ending the program.For resolve the problem i installed different version of KM player software but the problem remain in all versions.Anybody here to help me in this case?
How to ignore KM player hang problem?
I had the same freezing problem with forward and backward in KMplayer sometime but not often. That was only with Build 1431, I assume that was a bug in that Build. Usually the movie would get frozen and I had to use task manger to close it too. Reopen current file solved it. And at times restarting KMPlayer.
This problem almost disappeared in Build 1432. I don't have or ever had the problem you mentioned. Try downloading and install the latest build of KMplayer as this problem is not reported in the latest version as it was some code compatibility issue with the older version.
Maybe that problem you are experiencing is only with that version of KMPlayer you are using. I also experience the same problem when I am using one particular media player on my computer, the Total Video Player 1.20. It comes in package with Total Video Converter. The same thing happens as what you always see on your computer but not always.
Most of the time when I play an FLV video on my machine, the video plays but it is unscrollable. I can not scroll on the video using the progress meter to see the other scenes. There are times that my computer hangs up after moving the player’s meter.
 Try uninstalling your current version of KMPlayer and then check your computer for any possible errors. Use a disk utility application to check the system. Then visit https://kmplayer.en.softonic.com/download and then download KMPlayer 3.2.0.0. Scan the file for virus then open it to install KMPlayer 3.2.0.0 on your computer.
