How to image samsung hard dive backup
Hello Guys, How to image samsung hard dive backup. One of my friends suggested me to use Handy Backup by Novosoft, which he told is a program providing image files making for Samsung hard drive backup tasks. Please guide on whether it will help or is there any way to image samsung hard drive backup.
Answered By 590495 points N/A #141453
Here’s how you can backup your entire hard drive using Handy Backup. Before doing this make sure Handy Backup is already installed on your computer. If you don’t have it yet, download it from Download Handy Backup. Be sure to read the information first before you download the file.
The download button you see on the page will download the 32-bit version and the link below the button, “28.8 MB, 64-bit version”, will actually download the 64-bit version of the installer. See image.
Open My Computer then go to Tasks, New Tasks. Create a name for the new task then click OK. See image.
Look for your hard drive in My Computer’s list of physical devices. If you want to backup your whole hard drive, drag-and-drop your drive’s image into “What to back up”. On the other hand, if in case you only want to backup a partition, drag-and-drop an object from Partitions. After this, search for a folder in My Computer where you want to save the backup file.
Drag-and-drop that folder into “Where to back up”. See image.
Next, click Backup and the backup process will now commence.
