How to Implement RSS in my Site?
Asked By 7060 points N/A Posted on -
Hi Experts!
How do I implement RSS Feeds on my website? Is there a tweak to do this? How can I do this without using a huge technical effort? Can you site some examples of web based feed creation that generates RSS?
Thanks a lot.
Answered By 75 points N/A #81263
Hi Mdarifsadik,
RSS stands for Really Simple syndication and it is a text-based format type of XML. You can use RSS feeds to publish news feeds in your website or blog. With RSS feeds, you can improve the number of hits to your blog. You can use RSS feeds to create links to those links that are mostly accessed by visitors on your blog so that they do not have to go for those particular links or pieces of information.
There is a lot about RSS feeds that you will need to know including how they are implemented and I will refer you to the following sites:
http://www.webhostingsearch.com/articles/publish-your-own-rss-feeds.php
http://www.faganfinder.com/search/rss.php#disp
Hope this helps.
___
Lee Hung.
