How to import codes advanced notepad using java?
How to import codes advanced notepad using Java?
I am making a draft code for my bookstore system using advanced notepad with Java codes, instead of encoding it all over again manually I just thought if there are some ways to automatically import all the data in netbeans 6.9.
I need some advice.
Danield Make.
