How to Import Files: convert Outlook Express to Outlook 2007
Hi.
I have all my Files in Outlook Express. But, I want to Import them to Outlook 2007. Is there any way possible to do that? Can you please help me to convert Outlook Express to Outlook 2007? Thanks in advance.
Answered By 20 points N/A #84974
Hi. Yes there is a way to convert Outlook Express to Outlook 2007.
You just need to follow the below given steps:
1) Click on start then open the Outlook software
2) There will be a File menu on the top of the window. Click on it and then select Import and export option
3) Select Import internet mail and address
4) Then click on next
5) From the list, click on Outlook Express version that you have
6) There will a number of items listed among which you need to select the address
7) Click on next
8) Now, select wherever you need to Import the Files(Outlook 2007)
9) Click on Finish
