alwyn white
20 points
Posted on - 03/08/2012
hello
i want to import my gmail contacts list to outlook 2007. i applied to the gmail export procedure of building a csv file called-gmail-to-outlook.csv , i recorded in my documents.
what should i do to transfer outlook contact list contained in that file???
How to Import Gmail contacts to outlook 2007 ??
Since you already have the needed document to be imported to Outlook, which is the .csv file, follow these steps:
Open MS Outlook 2007.
Click File.
Select Import and Export.
When the wizard window comes up, select Import from another program or file.
Click Next.
Select Comma Separated Values (DOS).
Click Next.
Browse the location where your gmail-to-outlook.csv is located.
Select Do not import duplicate items.
Click Next.
Select where you want to place your Gmail Contacts.
Click Next.
Verify the action to be done by checking the Import contacts.
Click Finish.
Check your outlook if the contacts has been properly imported.
