How to import hp bios settings
Hi Experts,
I am trying to import hp bios settings in my Hard drive. Please suggest me the proper solution to import hp bios settings in hard drive. Thanks.
Jeviery Ero
Hi Experts,
Jeviery Ero
Hello Good Day,
Regarding your concern, you can use conrep utility to save your system ROM settings in a file in your hard drive. Conrep is a utility in the HP SmartStart Scripting Toolkit. There is a Windows and Linux version of the toolkit and you can download it here:Â
Hello there,
You can also download the bios from hp support and you can manually update your bios via floppy drive or using a flash disk drive. Run the exe file and there you will be asked if you want to back up your bios and from that option you can save it to your hard disk drive, And by the way never try to reinstall your bios to prevent any error.
Hope it helps.
