benjamin
460 points
Posted on - 12/13/2012
How to import image into access? Is there a way that a Microsoft Access database system will handle big images file? Would it possibly handle jpg, gif and png file formats? If there is some way that the ms access database can do so please let me know. Thank you.
Benjamin.
Its not usually recommended to store images in an Access Database because it bloats the size of the MDB. This makes the file more prone to corruption. A solution can be to store the files outside the mdb like in a table and store only a string path to the external file location in the Access Database. The string path can be used to display the images on forms or reports at runtime.
Thank you.
Hello
I would suggest you use “dbpix” to add pictures to MS access database easily and fast. The benefits of using this software are:
a) It is very easy and efficient. It has a seamless integration with MS Access DB
b) Prevents image GotChas like complex coding, performance problems etc.
To download dbpix follow click this link http://www.ammara.com/dbpix/access.html
Some of the technical capabilities are:
Has an integrated EXIF viewer
Also supports visual basic, Explorer in addition to Access
Has the ability to optimize on quality and storage space
