Hello Guys,
I need to know whether it's possible to import Publisher file to Corel, will all versions of Corel support this. If so, please do the needful for getting me the process of doing the same.
Thanks,
George Saunders
How to import Publisher file to Corel
One solution would be to get the publisher file printed to Acrobat PDF and then get it imported to Corel. Incase of the absence of Acrobat, please use a Post script printer and do the print to file option after which you can perform the import to Corel. Keep in mind that the publisher file will be in the RGB format when you are importing it to Corel, so the colors can be replaced by basic editing using find + replace.
