How to import a song from iTune library
I use LimeWire Pro and when I download a song I cannot import the song from my ITunes library.
I did the right click and explore open with ITunes but still I cannot play it.
The first thing to do is to make sure that the song is in a format that is accepted by iTunes, for example, MP3, WAV, or AAC. Then, open iTunes, click on File, and select either Add File or Add Folder.
Then, choose the song that you wish to add.
Adding files to iTunes library is quite easy, you can do this by either dragging the files to the correct icon on the left of the iTunes window from the Finder or Go to File, then Add to Library (if you are using Windows, select Add File to Library or Add Folder to Library), then choose the song file or folder to be added. iTunes normally adds the selected files to iTunes library and will also copy the files to your iTunes Music folder if this option is already selected from the advanced panel of the iTunes Preferences.
For more information on this visit this link:
https://www.techyv.com/questions/managing-computers-synced-iphone-itunes/
