Paul Baker
Posted on - 01/10/2012
How important network performance is in choosing a cloud provider?
Many providers are plugging out about their network performance, nevertheless how significant is the selection of cloud provider?
Which cases does it need for a top-tier network performance?
When it comes to network performance in choosing a cloud service, you will need to need to consider the service priority that will offer the best performance. When a packet of data is capable to take whichever route it wants, it could also take different spans of time, but that will dependent on the network conditions that have been set.
You will need to look for the service providers that will offer you the quality and the priority of service by the use of protocols such as the multi-protocol labeling service and also the 802.1p/q.
One other thing to put into consideration is how the tunneling or direct connection services that include dedicated or leases lines are part of the core functions.
Mathew Stone
