How to improve PC Performance
My computer has been acting slowly for a few days now. I regularly run defragmentation but I want to know if there is any other way to maintain my PC performance aside from this which I can run daily. Thank you.
Do not install unnecessary software, Install a powerful antivirus, try to use disk defragment in each month, you can use an antivirus for internet protection, if a serious problem occurs then you can use system restore, always check USB storage devices you insert.. After all these, I think your PC will perform well.
James Thomas,
There are multiple ways to get the top performance from your PC.
This can be obtained by, stopping the unnecessary services, reduce the startup applications, and some registry tweaks.
However, in my opinion, it will be best for you to use some reliable third party applications which can be freely downloaded and installed on your system. Some of these applications and their downloading links are provided below:
SARA
Many factors will effect on PC performance. Some have described below –
1 for registry error Run registry cleaner and fix them.
2 What antivirus you have installed on your machine? Install a good antivirus and run a virus scan.
3 Do you use internet daily? If yes then spyware have an attack on your machine. If your machine has a good anti-spyware then runs for spyware. If you not have any spyware program then find a good anti-spyware.
After that, is problem persists? Try these solutions also.
1 Check your hard disk work well. Replace it one time and check your system performance. Check hard disk connector also.
2 Check RAM has fitted well.
