ubarny
210 points
Posted on - 06/24/2011
Hi all,
I have lot of email accounts .All are very important. Everyday lot of email come to my address & also need to send lot of emails to others. My Gmail account performance is very low .
I can not send email in time. When I open a mail in my inbox,it opens very late.Â
Sometimes it not opens and just hangs. what is your suggestion?
Ferrell
How to improve the performance of my gmail account?
There could be some problem with your software, perhaps you need to clear your browser cache. Or maybe you are using Firebug, it can slow down your Gmail since it validates every XMLHttpRequests. So what you need to do is disable or just optimize Firebug.
Here are the steps to disable Firebug:
– Open Firebug by clicking the colored green icon located at the status bar of your browser window.
– Then, click Disable Firebug for mail.google.com.
Here are the steps to optimize Firebug:
– Select Console tab.
– Click on Options.
– Then uncheck the Show XMLHttpRequests.
– Click on Options.
– Next is check the Disable Network Monitoring.
Hope it will help your Gmail improve its performance.
Cheers
Hello Ubarny,
You can increase your Gmail account performance by doing following activities.
1. Delete unnecessary mail from inbox spam
2. Always use good internet connection
3. 1st Login to your Gmail and then Click Settings
4. Scroll to the bottom and Click the Bullet Always use https and then Click Save Settings
5. Refresh your Browser
6. Enabled HTTPS is for all GMAIL Pages!
Thanks and Regards
Manik
