hansmith
10 points
Posted on - 02/15/2012
Hi
I keep my raw data in my workbook and that workbook analyzes the raw data, and then creates a sheet (Total Sheet). Analysis workbook is ready for only up to one year and I would like to stay it that way. But now I want to add it up to 2 or 3 years (analysis workbooks) jointly to get one permanent file in a new workbook.
In a word I have to insert Analysis2009 with Analysis2010 as well as Analysis2011. All the data I need to duplicate are in rows below each other. The range will be the same.
Need your help. Thanks in advance.
How to increase the lifetime of a workbook
Hi
These problem shows that you are using such sort of device which you have shared with other computer also or your computer is connect to another computer due to which this problem occurs. Check if you are using the Wi-Fi___33 connection then your computer also on sharing and this may not work. One other option is you using any sort of internet device and you shared that device with other computer means another computer also connected to that device and that device allow your computer to share with other computer so your computer is on sharing and therefore this software is not ready to install and working on your computer so first disconnect to that Wi-Fi or the internet device install this and then run the internet device or Wi-Fi
