How To Increase Mailbox Size In Exchange 2010- Steps To Follow.
The default limit size set in the database of the mailboxes. Many at times we need to change the size. How to increase mailbox size in Exchange 2010?
There is a default limit set mailboxes in the database. Exchange management shell helps us in configuring the storage quota which controls the size of the mailboxes.
Step 1: Go to Exchange Management Control.
Step 2: Expand Server Configuration in console tree and then select mailbox.
Step 3: Choose the server for which you want to configure storage quota and then mailbox database.
Step 4: Select Properties in the action pane.
Step 5: Click Limits tab in Properties.
Step 6: After completing the fields such as Issue warning at (KB), etc and then press OK.
