How to increase more volume on dell?
Hello Experts,
How to increase more volume on dell? I got my new dell laptop and I want to get some more volume for sounds and other music and mp3 to play because the volume is not that loud as I was expecting. Is there any way to enhance this one? Any software enhancer idea will do.
Thank you.
Best Answer by Goram Ian
Answered By 5 points N/A #164932
You can try the Volume mixer. Just click the volume icon on the task bar and click the mixer link. If it does nothing, right click the icon and click Volume mixer. You can adjust the volume to 100% to be able to enhance the sound. If it fails, you can also try this software that can be downloaded here:
http://www.winsite.com/dell/dell+laptop+volume+enhancer/
Thank you.
Answered By 60 points N/A #164934
Hi Janet Campbel,
I have read your post and it was very common question on other forums. You can check the best answers in the following links below:
Yahoo Answers: How to increase the volume on my Dell Laptop
Yahoo Answers:How can Increase Speaker volume of Dell Inspiron 1525
Wiki Answers: How do you increase the volume on a Dell Inspiron 1525 laptop
Hope that it would help you a lot.
Thanks and more powers.
Answered By 10 points N/A #164933
Although there is no such software that helps in boosting your volume the thing you can do is to upgrade your sound card or speaker device to get more volume. If your dell laptop has the sound increase key then try to increase it from there or use external speaker to boost volume of your laptop.
Smith Thompson.
