How to increase the speed of my internet?
I am using internet through mobile and I am having problem with it as it is very slow. Is there any way to make it perform faster.
I am really fed up. Please help.
Hello Christian Briggs, I will be needing some more details of the mobile and the service provider you are accessing for the internet. It solely depends on the brand and type of service you are using. As GPRS/EDGE is not the fastest of all but if your mobile is integrated with the WLAN/Wi-Fi then you do have a chance of using fast internet speed.
Or there may be some other services you are using. The thing is when using internet on the go you have to compromise for the service you want. But if you are in the range of some Wi-Fi hotspots then you can catch up with the high speed internet.
Hope this will help you in recognizing the issue you are facing and the slow speed of your mobile internet. Thank you
If you are browsing the internet on your mobile phone and it is very slow, the fastest browser I’ve ever tried both for PC and mobile phone is Opera. If you are using an Android, the Opera browser is available on Google Play. You can download either the regular browser or the mini version.
The Opera browser is available both on Android and iOS so you can use it on either device. For Android, you can download Opera Mini at Opera Mini on Google Play. Compatibility varies depending on device. For iOS, download it from Opera Mini on iTunes. It requires iOS 7 and higher and works on iPhone, iPad, and iPod touch.
If you want the regular browser or version, download it from Opera Browser on Google Play. Compatibility varies depending on device. For iOS, Opera Mini is the only version available.
Notifications
