How To Increase Upload Speed- Way To Do It.
We often come across a situation where the uploading speed of the internet is slower than the downloading speed. How to increaee upload speed?
Your internet uploading speed depends upon the service providers.
You need to upgrade your service to achieve faster upload speed. You need to check if bottleneck exists by troubleshooting your network and computer.
Step 1: Reboot your device and also the switches, modems, or routers.
Step 2: Run a bandwidth test.
Step 3: Make sure there is no virus or malware. Remove them with the help of antivirus software.
tep 4: Choose if you can discard any router or switch which is in use.
Step 5: Upgrade your internet services.
