How to increase/decrease the line spacing.
I used to copy articles form the web (news sites/blogs/…) and the format differs from one site to another.
I am able to unify the font, the color, and the size, but some articles have different line spacing (space between each line), some article has a 1.0 line spacing and no space between paragraphs while another has 1.15 line spacing and a blank line between paragraphs.
How am I able to specify these spaces?
Any solution/link?
Best Answer by Peter09
Answered By 0 points N/A #126724
Depending on what version of MS Word you are using, finding the tools for these vary though they may be similar. For most if not all MS Word versions, the easiest way to change the line spacing would be to:
  • First highlight the section that you want to add or remove line spacing.
  • Then right click with your mouse and a box with some options will appear.
  • Select paragraph and another pop up box will appear.
  • Under the Section spacing you can change the spacing before and after the sentence, you can also add a fixed line spacing such as Single, 1.5 lines, double, exactly, and the like.
Answered By 0 points N/A #126726
The Office programs differ depending on the generation especially the font used in a website cannot be exactly the same as the one established. So, the specific line spacing depends on the font type.
