How to initiate automated download to nas Mac?
I want to use NAS for both the purpose of backup and storage. I do not have the appropriate NAS and its facilities. How to initiate automated download to NAS mac?
Please help.
Please help.
The Iomega NAS is a very good tool for the purpose of backup and storage. You can download it for free from the app store. It is also easy to install and use. Just follow the steps below:
1. Go to https://www.macupdate.com/app/mac/9141/iomega-nas-updates and download the software. Save the setup file on your disk.
2. Run the setup file and install the software on your system.
3. Check the compatibility of the software with your system and then download the version which is supported by your system.
4. Now restart the computer for the changes to take place.
Hope this information helps you.
NAS is a short term that refers to Network-Attached Storage. It is a type of dedicated file storage that offers file-based shared storage to LAN nodes or local area network nodes using a traditional Ethernet connection. A NAS device normally doesn’t have a display or a keyboard. It is managed and configured using a browser-based utility application.
Every NAS exists in a local area network as an autonomous network node with its own IP address. Its major benefit is its capacity to provide multiple access to the same files from multiple clients. Before NAS came, it is normal for an enterprise to have hundreds of discrete file servers that had to be individually maintained and configured.
But when NAS was introduced and you need to have more storage capacity, you simply need to equip NAS appliances with bigger disks or clustered together to give both horizontal and vertical scalability.
