How to insert PDF file in Excel Sheet?
1. Open an new Excel Spreadsheet and choose the place where you want to embed the pdf object.
2. On Excel 2003 version click insert on the later version click the Insert ribbon.
3. Select the menu Object to insert an object.
4. Then a new window will open, from here you will need to select the Adobe Acrobat Document.
5. Then look for the pdf document that you want to insert in the excel file then choose it. Finish the set up and there you go, you have your pdf file link in an excel document.
Note: When you open the file, it will still open in a separate window and needs Adobe Acrobat Reader installed.
To insert a PDF into an Excel 2010 worksheet, do the following:
