How to insert picture in MS Word?
Asked By 120 points N/A Posted on -
I am struggling with inserting a picture in MS word.
I have picture in jpg format and I need it to be pasted in the word file.
Basically I am working on a project in which I have to add graphs tables and pictures.
Please guide me.
Best Answer by robertlord8899
Answered By 0 points N/A #86036
To insert picture in the Microsoft Word follow the following procedures:
  1. Open your file of MS Word
  2. Go to the Insert Menu at the top
  3. Here you will see a tab of picture
  4. When you will click the picture a new window will open
  5. Browse the picture and select it
  6. Click insert to complete the process
  7. Now you will see your pictures pasted in your Word file
  8. You can adjust its size and place according to your demand
  9. Now the job is done.
Answered By 0 points N/A #86037
Hi dear,
This is quite simple task can be perform only by using mouse. Please follow these steps as written here. Place your cursor (current screen operating region) by clicking the position on word document. Click the insert menu from top and then picture tab you will find clip art tab then select any image given into the clip art gallery or select it from your hard disk, select image and click insert when the image been selected into your word document then you can resize the image by dragging outer edges. Your Job has been accomplished.
Answered By 75 points N/A #86038
you can drag the photos in ms word as simple as that
or you can copy paste the pictures
