How to Insert StraightTalk Card in Lenovo A880 Unlocked Phone
I recently purchased a Lenovo A880 unlocked phone from China but I am unable to figure out how to insert a straight talk sim card in it. I have tried inserting the straight talk sim card in it but the phone keep saying card not detected. I am not pretty sure whether the way I am inserting the straight talk sim card is the correct method. Could someone kindly advise on how to go about it? Thanks in advance
Answered By 5 points N/A #180733
The Lenovo A880 is amazing, Affordable, Big beat, It looks good, And feels better, It is also amazing for watching videos, And surfing the internet, Inserting SIM card in Lenovo A880 can be little tricky, It supports dual SIM card, So it has two slots for SIM cards, One above the other The first SIM card angel side should be in the right, While the beneath SIM card angel side should be placed in the left, If this doesn’t work, Try another SIM card to ensure that the device is ok, If another SIM card works, You should get new straight SIM card, As it might be damaged.
