How to install ad aware professional in my laptop?
Greeting everyone. I need a step by step guide on how to install ad aware professional for my Windows XP laptop. What are the key features of this ad aware? How is this different from any other anti-virus and anti-spyware software out there? In terms of efficiency, what is your own rating on this product?
Answered By 0 points N/A #129944
Hi Ruth!
Ad-Aware Pro Security has the most advanced anti-spyware and antivirus detection feature. It has two-way firewall, USB guards, email protection engine and advanced web filters against phishing attacks. Ad-Aware Pro Security's performance is better than average. It can detect many and in some cases most of the threat's you will face on a regular basis. It protects you against cyber criminals out to steal your credit card data or banking information when you are shopping online. It also keeps your passwords and personal information safe on social networks.
To install Ad-Aware Pro Security:
  1. Double-click to open the installer file that you have downloaded
  2. Select preferred language
  3. Default destination folder is set to C:Program FilesAd-Aware Antivirus
    Click on Change button to alter the destination folder. Tick the box that would allow you to create a desktop shortcut. Read and Agree with the License Agreement.Then click on Next button.
  4. It is recommended to install the Ad-Aware Toolbar so make sure that you tick the box for this option. Then, click on Next button.
  5. Installation will now run. Once done,click on Finish button.
  6. You will be advised to reboot your computer. Follow the prompt or click No to reboot later.
You can also view the PDF manual for Ad-Aware Pro Security.
