Ma McKinney
50 points
Posted on - 07/08/2016
I am trying to download Adobe acrobat 64-bitWindows 7but I am not able to install it on my PC. But it is not installing and always ends up in internet connection failure. Is there any way to download it without the internet?
How To Install Adobe Acrobat 64-bit Windows 7?
To download an offline version of setup is also possible. If you have a stable internet connection, you can use the normal setup file itself. Since you have a fair internet connection you may not be able to download the version using setup file. You should refer the below given link and need to select the file required to be downloaded.
http://www.Adobe.com/support/downloads/product.jsp?platform=Windows&product=10
