Dear Techyv Friends,
Please do the needful for providing me details on how to install Adobe CS5, If anyone can provide me the installation tutorial for Adobe CS5, that will help me a lot.
Thanks & Regards,
William S Jackson
How to install Adobe CS5
Hi William,
I will teach you how to install Adobe CS5. But before you install the application you need to make sure that your computer meets the system requirement of this software to avoid any error during installation.
Follow these instructions to install the Adobe CS5:
Step 1: If you are using the installer from the DVD. Put your DVD installer to your DVD drive.
If you are using an installer you download from the internet. Open the folder where the installer located.
Step 2: If you are using the installer from the DVD. If the installer is not auto run, you need to double click the setup.exe file then a welcome window will appear.
If you are using an installer you download from the internet. Double click the setup.exe to start the installation then a welcome window will appear.
Step 3: You need to check the checkbox for "I agree to Adobe's Software License Agreement" for you to continue the installation process. Hit next to continue.
Step 4: The software will ask for your Adobe ID to register the software and also for you too can access to "Adobe CS Live". If you don't have an account on Adobe you can create by clicking the "Create an Adobe ID".
Step 5: You can select your language you like for your software.
Step 6: When ask for a serial number, enter it and hit next
If you are using the installer from the DVD. You can see the serial number at the back of the case
If you are using an installer you download from the Adobe website, they will email you the serial number.
If you don't have a serial number because you just copy the installer or the download this for free, don't worry you can still install this to your computer by choosing the 30 day trial but after 30 days you cannot use this software unless you already have a serial number for this.
Step 7: Choose for the Adobe component listed you want to install or better choose all the component to make sure that you won't miss any important component that the photoshop needs. Then choose a location where you want this to install.
Step 8: Hit installs to start the installation wait until it's done
After you successfully install the software you can now start using it. I hope this can help a lot.
