How to install Adobe Photoshop CS5
How to install Adobe Photoshop CS 5. Please guide me step by step.
Thank You
Answered By 0 points N/A #160206
I can't find the question there but in regards to Adobe Photoshop cs5 installation, this application is easy to install. It would just take several minutes. Just make sure that your computer meets its minimum requirements. And by the way, MAC OS X and Windows has different requirements.
Regarding the memory, it would be better if you have at least 2gb of free memory or more since Photshop 5 requires 1gb of memory and there are other programs are using the computer's memory as well. There should also be a plenty of storage space on your hard drive.
Also check if you have the appropriate Videocard and support OpenGL.
That needs at least 256 Mb RAM.
You can find the steps on how to install Adobe Photoshop cs5 here
Answered By 590495 points N/A #310294
Before installing Adobe Photoshop CS5, make sure your computer meets the requirements. Adobe Photoshop CS5 supports Windows XP Service Pack 3, Windows Vista (Home Premium, Business, Ultimate, or Enterprise edition) Service Pack 1, and Windows 7. It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor, 1 GB RAM, 1 GB free space, and 1024 x 768 pixels minimum screen resolution.
Some of the features that require GPU acceleration require a video card with OpenGL 2.0 and Shader Model 3.0 support. Once you verify that your system is compatible, you may now proceed on installing the application. If Adobe Photoshop CS5 is a download, just double-click the installer you downloaded and follow the instructions.
When you are prompted for the serial number, just enter your serial number exactly as it appears.
