neil guyson
Posted on - 02/12/2013
Hi everyone,
I am here to get the solution of my problem. I was using Windows XP and for CD Burning I used alcohol 120% 1.9 software. It is very good and easy to use software. It produces high quality CDs. But Now my desktop computer is crashed and I want to use this software on my Laptop running on Windows Vista. I am unable to install this software on my Laptop. Please tell me how I can install alcohol 120 on windows Vista. Is there any version available that supports Windows Vista?
How to install alcohol 120 on Windows Vista?
Last night I was installing Alcohol 120% and I have no idea that it wasn't compatible with Vista! I just learned about the "not-compatible-with-Vista" just now. I have a Factory Boot CD that I burned when I got my laptop. I think I can reboot it with that. But my problem is I have many files in My Documents (and other places) that I haven't backed up. My problem is I want to save/ back up all my files first before running the boot CD.
If your laptop has Windows Vista, I don’t think that’s a problem because the operating system is supported. If you can’t install the program, it probably means you are using the free trial which is valid only for fifteen days (15). Check if the trial period is not expired. If the problem continues, download the free edition. Try downloading from here:
Alcohol 120% and 52% supports Windows NT, Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It doesn’t support Windows 98 and Windows Millennium.
