Jeremy Jack
30 points
Posted on - 11/10/2012
Hi guys,
How to install an amiga computer theme?
I do have a computer dell desktop with an operating system of windows 7 starter 32 bit which is very sensitive when It comes on allowing software to be installed.
What should I do to get the correct installation process?
Expecting some help, thank you.
Dear Jack,
I read your problem. It is very easy. Follow these steps
i) Download Amiga theme from this link – https://www.windows7download.com/win7-amiga-explorer/download-jlpynomi.html
ii) Go to the download location.
iii) Double click installer.
iv) Click next.
v) Select I agree with terms in the license agreement.
vi) It doesn’t need any license key. So click next.
vii) Select standard install.
Viii) Select location. (Don’t change old one)
ix) Click next/ install.
It’s done.
Thank you
It is very easy to download. You just Download Amiga theme.
You will have to Go to the download location.
Then Click next and Select I agree to the terms in the license agreement. It doesn’t need any license key.
So click next and Select standard install. Then Select location. (Don’t change old one) and after that Click next and install.
I hope it is helpful to you.
