Hello fellows,
How to install and load ipx windows 7? The software was already in my computer download location and all I have to do is just run the program. What will I do next after running the application? I need your guidance on the step by step process.
Brenda Lopez.
How to install and load ipx Windows 7?
Hi Brenda Lopez
Here, you are seeking help for install and load ipx in windows 7.
You are trying to install it  but because of some mistakes , you are failing  to do so .
I think some good tutorials and help manuals can help you solving this problem. You described you pc configuration.
That is windows 7 OS . This is good for doing such installation .
So see how you can from this link.
May all this makes a good helping blend for you.
Thanks
