Hello Friends, I am using Windows XP and would like to know about how to install and use PowerDirector 10 in my system. Also do the needful for helping me by providing me the download link towards PowerDirector 10. Thanks
Both CyberLink PowerDirector versions 10 and 11 are outdated. The latest is CyberLink PowerDirector 12. This version supports multicam editing and features an enhanced render times by taking advantage of Haswell, it is Intel’s latest core processors. This version can encode H.264 videos 40 percent faster than the previous ones.
MultiCam editing and ShakyCam reduction are the latest features that were added to CyberLink PowerDirector’s tools. With the ShakyCam tool, it zooms a little on a scene and tries to lessen shakes by means of counter-rotating or panning every frame. It works on normal videos but it can’t make any miracles to happen on videos taken during earthquake.
The MultiCam tool can very well synchronize your video using the audio spikes. You can cut in and out of every scene by simply clicking the particular footage. Unfortunately, this program is not free but you can still use it for 30 days with its free 30-day trial period. The full registered version costs around $100. To download, visit CyberLink PowerDirector 12.
This version works on Windows XP, Windows Vista, Windows 7, and Windows 8. Installing it would be simple. Download the latest version by clicking on the link I mentioned above and then save the file on your hard drive. After downloading, go to the folder where you save the file and then double-click it.
Follow the succeeding instructions until it is finished. Also watch “How to download install and use PowerDirector 10 | tutorial video by TechyV” to learn more.
1....
