How to install animated themes Samsung wave? I have to know the process of installation to avoid any problem along the process. I just downloaded some animated themes which is compatible with my Samsung wave operating system and planning to install it now. Can you suggest a secure way of installation? I don’t want to risk the safety of my mobile phone.
These are the following steps to install animated themes without any problem.
Since you have already downloaded some animated themes which is compatible in your Samsung wave OS, then the icon will appears on the main menu. Click it. When it open, Different views that are associated with the theme and the three button (Idle, Menu and List) will appear. There shall be two buttons even at the bottom of the screen. Click the “Install the theme” on your phone. After installation you should set the theme on your phone. To set it, go to the Settings icon ( main menu). Click the Display and Light option. Then, select the theme that you have installed. Finally, click the “Set” button.
The Samsung Wave phone is a Bada phone and it’s very unlikely that you will still find animated themes for this phone nowadays. The Samsung Wave 723 S7230E is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on August 2010 and released on October 2010 measuring 109.5 x 53.9 x 11.8 millimeters and weighing 113.8 grams.
Samsung Wave
It uses mini-SIM card. It has TFT capacitive touchscreen display with 256K colors at 240 x 400 pixels screen resolution with TouchWiz UI 3.0. It ships with Bada OS. It supports microSD expandable up to 16 GB with 90 MB internal storage. The primary camera supports 5 megapixels with AF featuring LED flash. It supports 320p video recording at 15 fps.
There is no secondary camera. It has 3.5-millimeter jack with DNSe (Digital Natural Sound Engine) support, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 3.0 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS and recording support, and microUSB 2.0. It has built-in accelerometer sensors. The pre-installed web browser supports WAP 2.0/XHTML and HTML.
It runs on removable Li-Ion 1200 mAh battery with standby time up to 700 hours on 2G and 600 hours on 3G. Talk time is up to 14 hours 20 minutes on 2G and 6 hours 45 minutes on 3G. It is available in Black and White/La Fleur edition. If you want, download Samsung Theme Designer on Softpedia and create your own theme.
1....
