How Install Animated windows icon
I am using window 7. I want to install 3D animated window icon but I don,t know how I install it. Please tell me how I install from internet free of cost. If any body have working URL please suggest me.
There are many software’s available for you. From that URL you can find many software’s and you can download that for free:
https://en.softonic.com/s/windows-7-animated-icons.
If you want to know that how the software works then i am sending you a tutorial. I hope that will help you.
Thank you.
To install your animated icons first is you must have software that compatible to your windows. I find a source to your problem as I’m searching on the internet I want you to click this site. I suggest you to watch the video:
Hope you can now install your animated icon by using this tutorial.Â
Thanks and regards.
