How to install avec webcam driver?
I just reformatted my computer and go for windows 7 64 bit operating system. I am having a problem about installation of the drivers. How to install avec webcam driver? Can anybody help me out of this?
Aabel.
Best Answer by Maud Matland
Answered By 0 points N/A #146107
The problem is occurring due to the unsupported driver version of webcam in your OS. You should download the Win 7 64 friendly version of your webcam. Visit the certified webs site of your webcam. Find out the friendly version and install it. If it was unsuccessful, then use the search engines for finding out the well-matched version.
Answered By 0 points N/A #197103
The simple and easy way to download the right driver for your webcam and it will work perfectly. You just need to follow some instructions to find the driver.
1.    Open Google site.
2.    Write “avec webcam driver” with the exact model number in Google search bar which should be available on the webcam.
3.    Then find the right driver with model number and download.
4.    After download, install it.
I hope it will work perfectly.
Answered By 590495 points N/A #328144
If the webcam you purchased came with a CD, you can find the driver on that CD. Just insert the installation CD on your optical drive then run the installer to install your webcam. If the installation CD contains multiple drivers, try every driver. If none of the drivers worked or the camera doesn’t come with an installation CD, you can use ManyCam.
Download and use ManyCam instead. It works on any webcam as long as your operating system is supported. It supports Windows 7, Windows 8.1, and Windows 10 and requires Intel Core i3 or faster processor, 2 GB RAM, and internet connection for subscription activation.
