How to install client oracle 9 no windows 7 64 bits
To set up DB environment similar to my Office, I installed Oracle 9i on my Windows 7(64 Bit) in my laptop, but it is quite confusing. can someone help me the simpler way to do it.
Greetings to you!!
I think, it is not compatible ever with windows 7. You cannot run it by windows 7 operating system. So, if you want to run you need to change your operating system. You can try to do this in Windows XP, Windows vista and Linux. Then, I think you could enjoy everything.
Thanks
Hello Priscilla,
Your Oracle version is not compatible with windows 7 64 bit. You need to change your operating system if you want to use it. Otherwise, try to install another one which is fully compatible with your operating system and do a clear install. If you have previous Oracle then you need to uninstall it and clean the registry.
Thank You.
