How to install codec in LCD TV ?
How to install codec in LCD TV, The video is coming but no sound and is getting a message "Audio Codec Not Supported". Please  Support.
Hi, Davis!
Unfortunately, it is impossible to install codec to TV. Supported formats/codec are in the user's manual. You should update your TV firmware. Go to manufacturer site, download the newest firmware and install to TV. If your TV is capable to connect to the internet then just select menu item and the TV will update itself.
Regards!
Here’s some steps in adding MKV and DIVX’s CODEC:
1 – Enter the Service Menu (when in standby hit info, menu, mute then standby)
2 – Enter 'Control' option
3 – Enter 'sub Option'Â
4 – Turn on WISELINK MOVIE, WISELINK WRITE & HIGH DEVI
5 – Press Standby Hope it help.
Dear Devis Millers,
I understand your problem. You want to install codec in an Lcd TV. There are different ways for different brands of TVs. You have to find out the brad of TV. Generally you can find codecs for Samsung, Philips, Sony etc. very easily. There are also few brands of TV where you can't install codec.
Thank you.
