Hello Techyv members.  Please tell me how to install com port data capture software effectively? What are the steps needed for this? Please kindly include an overview and detailed step by step guide for the installation. I would also software recommendations from experts in terms of com port data capture. I'll be waiting for your answers.
How to install com port data capture software effectively?
I recommend you to use this software the Port Analyzer. You can download this for free. With this software, you can monitor data throughout your local computer and remote host packet. Its support capturing network packets bypassing the protocol stack. It also supports most Windows Operating system such as Windows XP, 2003, 2000, 7 and Windows Vista. This software is very useful and can easy to use. Can support a remote host with Windows and Linux host.
Click this link to download Port Analyzer:Â https://softwiki.net/Process_And_Port_Analyzer.html
After downloading the software:
1. Launch the installer
2. Follow the instruction given by the installer.
Note: this installer will automatically detect your OS and install all files that needed in your system.
3. Run the software after the installation. You can now use it.
Features of this software:
1. Small and Handy Tool
2. You don't have to install other software libraries for the requirement.
3. All capture from the network trace can be saved to your computer disk.
