How to install compuserve Plugin?
I just want to know if how to install CompuServe plugin?
And how is it related to any multimedia applications such as adobe photoshop and etc.
I am willing to learn more about this matter.
Thank you
Best Answer by Allen Kenneth
Answered By 0 points N/A #146555
Hi ,
For installation of Compuserve plug-in, you should download the plug-in software from the provider website.
And run it.
Now, pull the plug- in to the File folder option of Photoshop’s Plug-in icon.
After this step, exit from Photoshop and start it again.
For further help visit here
Answered By 20 points N/A #146556
Hello Michael,
Many image file formats which differ from each other are available in Photoshop Element but many people probably will opt to use only a few. Among them The Graphics Interchange Format or GIF as you commonly identify, It was developed by CompuServe. Main feature of CompuServe GIF format is that it supports animations.
You can download the CompuServe GIF Plugin update here
Refer the info on the same link, if you came across any difficulty in installation process.
Hope this will be helpful. Regards!
