How do I install Centos operating system on my Windows machine? What steps must I follow to get the best possible result with no hitches? Are there any particular applications or programs which might affect the installation process? What precaution must I undertake to make sure I have a smooth installation of Centos?
How to Install, Configure and Use Centos Operating System
Hi Guys, I am going to share a full guide to install centos OS with images.
First of all select upgrade or Install in your existing system.
Now follow the 2nd image which tells you to click on skip.
Now click on Next from Centos welcome screen and choose the language as shown in the image.
Now select appropriate keyboard and Basic storage device and press Next. And follow the further instructions.
Now configure network, to do this you need to give a host name as shown in the image and then click on configure network.
Go further step by step and you will complete whole the process. If you need any help in installing then visit on the following link where all the things describes in the better ways with images.
Check this link: Centos 6 Installation Guide with Screenshots
