Hello everybody,
How to install countdown alarm gadget? I just installed my windows 7 starter 32 bit operating system in my HP laptop and done with all the important updates. I get a countdown alarm gadget zipped file, how to properly install the gadget?
Thanks and have a nice day.
Hi. Timothy Raine
I searched a solution that may help you solve your problem.
I think you use this software you windows countdown alarm.
1. You download this software this link. This is 212 KB software.
http://www.softpedia.com/get/Windows-Widgets/Alarms-Clocks/Countdown-Vista-Gadget.shtml
2. You install this software
You just installed my windows 7 starter 32 bit operating systems in your HP laptop and done.
Enjoy this software
Thanks
Carrie Westmoreland
lee hung
75 points
Timothy,
There are several download sites to get a timer/alarm clock system loaded on your desktop. The site I'm providing you allows you different themes and alarms so you can customize the download to your preferences once you have it installed. The site where you can get this alarm system is:
http://download.cnet.com/CountDown-Timer/3000-12565_4-10715717.html.
Namal
Dear Raine,
As I understood, already you are zipping a file which is having a countdown alarm. Below solution is given based on considering you had admin control of your system.
1. First you check whether the zipped file can be opened with your computer.
2. If you can open it, extract the file to a location where ever on your hard disk.
3. Double click the file ending with exe extension.
4. Follow the instruction carefully.
5. If you unable to open zip files, download WinZip software & install it first.
6. If you'r looking for another countdown alarm, please follow below link.
http://download.cnet.com/Free-Countdown-Timer/3000-2350_4-75330413.html
Hope you will install countdown alarm with this tip.
Thanks
Namal
