Tuan Riggs
Posted on - 07/26/2016
Hi Guys and Girls,
I can’t install the ActiveX Crystal Report Viewer on my Internet Explorer. I have downloaded the package. Someone, tell me how to install Crystal Report ActiveX Viewer Control on the IE7?
How To Install Crystal Report Activex Viewer Control On The Internet Explorer?
You should follow the steps.
1) Perform a Clean Boot of the system to check if a Third-Party Application is causing the problem. The link is https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows.
2) Optimize the IE to determine the Problem. Here is the link. https://support.microsoft.com/en-us/products/internet-explorer.
3) Now, open Internet Explorer.
4) Choose the Trusted Sites, and then click on Custom Level. 5) Now, select “Enable ActiveX Controls and Plug-ins That is all you got to do.
