How to install D support from D7/
I am trying to install D support from D7 but not going through. It gives me an error “Cleaner can’t be found” where I am I going wrong? The D7 is located in 3rd party tools and the cleaner works well with main part of D7. Someone please assists me I am stuck completely.
Answered By 15 points N/A #107532
Hello Mark Santos,
I think there must be some registry files that must have been corrupt or are missing and therefore resulting to the error that you are getting when you try to install D support from D7.
But good news is that there are some good programs that can fix the registry issues so that you can go on with the installation without having the trouble like the one you are going through right now. I will recommend for you one program called Registry fix. Once you have installed it on your PC, you will need to launch it and use it for scanning for any invalid registry entries which are responsible for the PC issues. It will also inform you the location of the errors and what might be the possible cause to them.
You can get this application from http://www.registryfix.com/
__
Regards
Clair Charles
