I know that damn small linux installation is a risky process. I never did it but before two days , I had tried to install it . I created a app 275 MB Linux partition with fdisk. It took boot into damn small linux by using CD but I was getting problem in bios . So, I need to know the accurate install process. Please help me anyone .
How to install damn small linux accurately?
As u mentioned, installation of damn small Linux (DSL) is a risky process. Here is the procedure on how to go about it:
Create an application 250-300MB Linux partition with cfdisk or fdisk
Boot into Damn Small Linux from CD and enter the terminal
Execute “dls-hdinstall” by typing “sudo –u root dls-hdinstall” (with no quotes) and enter the created partition.
Execute “mkliloboot” by typing “sudo –u root mkliloboot” (with no quotes). Enter the partition that you install it on. This creates “initrd” and sets up “LILO”.
Thank you.
Hi Ohammer,
DSL is a very versatile 50MB mini desktop oriented Linux.
Damn Small is small enough and smart enough to do the following things:
Boot from a CD as a LiveCD
Boot from a USB flash drive
Boot from within a host operating system
Run a 486DX with 16MB of Ram
Run fully in RAM
DSL is highly extendable without the have to customize
You will get more information from here:
https://www.pendrivelinux.com/all-in-one-usb-dsl/
Thanks For Asking.
