Hello everyone. Can you please help me how to install data compression viewer effectively? What is the first step for this task? Please include a step by step guide for this. I would really appreciate it if you could give me its key features and system requirements as well. Thank you so much.
How to install data compression viewer effectively?
Hi Rubyjmorales,
I would suggest that you use the WinRAR application for your query. It is a data compression tool that provides a good algorithm in compressing data, also, you can view what's inside of compressed files, however, WinRAR is limited to these file extensions only:
RAR
ZIP
CAB
ARJ
LHZ
TAR
TAR.GZ
BZ2
TAR.BZ2
ACE
UUE
JAR
ISO
7Z
Z
If you want to open data files with different file extension, you can search to source forge for best results.
