How to install desktop camera recorder? I want to connect my camera recorder in my computer desktop but don’t know how. Would you give me a fix and accurate instruction? This is very important for me. There are some files needed to be viewed from a camera through the computer desktop.
Thank you.
Mellisa Wright.
It is possible to make videos of what happens on the screen. For that, there are two free software: CamStudio and Wink. These programs are not at all suited to capture video stream (webcam or games). CamStudio Screen Capture allows continuous output AVI or SWF (Flash). It also allows you to record voice. The second one is Wink and allows you to make screenshots automatic (on mouse actions or keyboard key or timer), as well as capturing mouse movements or audio capture (optional).
Hi Mellisa
To install your camera recorder to your desktop simply, plug in the USB cord from your camera to your desktop it will automatically install the camera.
And you may also download Cam Studio, it records all screen and audio activity on your computer. You can record anything in your desktop.
