Angela King
10 points
Posted on - 10/03/2012
Hello guys,
How to install diagram of zone alarm firewall? I did install software related to this one and I am very disappointed that it didn’t go through the installation process get stuck. Now I want to ask you if how will I be able to get this done properly. I need to install this as soon as possible. Thank you.
Hello Angela,
Are you sure that the setup you are using to install the zone alarm firewall is fine, because you might be getting that error because it is corrupted. You will also need to check for compatibility issues and ensure that the zone alarm app is meant for the OS that you are using.
Nicke
Dear Doriswneil,
Try to download and install the latest adobe flash player from the following URL:
1. If you use Internet Explorer:
2. If you use other browsers:
http://get.adobe.com/flashplayer/otherversions/
These versions are compatible with Windows 2000 and won’t cause kernel DLL errors. It is recommended that you use Internet Download Manager to download them.
Best regards,
Don Muench
