How to install Digital Scale on iPad?
Hi Experts,
How can I install Digital Scale on iPad? I need the step by step instructions on how to purchase it.Â
Calistamadisonn
Hi Experts,
Calistamadisonn
Hi Calistamadisonn,
You can download and install Digital Scale from your iPad iTunes App Store. Just go to the App Store and type Digital Scale from the search box and then click Install. This application should be purchased in order to install it. Here is the link for more information:
https://itunes.apple.com/us/app/digital-scale/id351060774?mt=8
Hi There,
Thank you for your sensitive query. I can definitely help you with it.
All you need to do is just got apple store and then you can directly download Digital scale to your iPad, but you have to keep in mind that you need to pay for the download from apple store.
I also have an alternative that you can use to download the same, but I would recommend you download it from apple store.
Hope this was helpful.
Bell Keny.
